Mozzy
Mozzy's Avatar
03.23.2012, 12:35 PM
Is it a Leopard motor by chance?
You're right about your set up, it sounds just fine.
If I were you, I would try a different motor.
I heard from a guy that bought a Leopard motor (not saying yours is) & it heated up the wires & was running well within it's limit, but, it ended up frying his ESC for some reason. He has never discovered why nor has had the opportunity to run a different motor for testing on his now toasted ESC's.
Just some ideas I thought I should throw out there.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
