IrishChamp
04.03.2012, 02:56 AM
Glad to hear that, do you think 3mm aluminum would be strong enough if I decide to try and replicate the piece in aluminum? Either way I might sandwich the center diff between two plates top and bottom, I'm sure that would add a lot of rigidity. My plan is a little up in the air again however, the mount I have does not accept the m4 screws used on the Neu 1527 and I haven't decided which way to point the motor to allow space for the batteries while achieving descent weight bias (more weight up front but not too much), I just can't find a diff mount that makes things adequately simpler to justify the price.
Delrin is pretty tough stuff, but that's a big truck thats going to have big power too. I didn't realize the plate was 3/8 thick, I'd think you'd be ok with that.
