03.26.2005, 08:59 AM
Hey, Monster Mike, what motor/controller did you use in your T2 to make it clock at 65mph? I think I was able to make such speed with my B4 when it was equipped with a Kontronik fun480-42 motor@12volts the buggy even lift the front end when it reached its peak because of excessive pace. Now I'm using the Lehner 1920/8 motor on the B4 with a Kontronik 55-10-32 controller, but strangely enough the car doesn't accelerate as fast as when it was with fun 480, although the 1920 is "torqueier" than the 480. I think the problem is in the esc itself because the motor might be draining more amps from the esc than the 480. the 480 drains 40 amps continuous and 60 amps surge, but the 1920/8 might be draining much higher amps than that whether continuous or surge, but either way I would like to hear from you people.
Nice to meet you!
