04.26.2012, 01:14 PM
Originally Posted by Big House View Post
Arct1k,
I appreciate the info. Upon further investigation and using your pics, it is an LSTII. I guess I can refine the parts search. The only thing with the center spool out of the GTP, the cups are a bit short so I will need a longer rear CVD. I have a Mayhem ST with a beefy rear center shaft. If can find that I will be golden.
I used a dm-1/gtp spool in my E-LST. (I believe they use the same spool?) Anyway, the shafts barely sit in the cups but it does work. They are actually sitting in the cups farther than the shafts sat in the lst transmission. Pic:
