You can sleep in a car, but you can't race a house
05.11.2012, 11:18 PM
Well, just got the diffs disassembled tonight and re-arranged the electronics.
The manual says the Diffs are filled 1/5/1. Thats false! The manual may say to use 1/5/1 on the diffs but in actuality they are simply greased.
I put 7/30/5. The 30k is a little heavy for a first try but I only had 1/3/5/7/30/60 to choose from. I use 150k in my 1/8th truggy to keep the 6S power under control so I'm used to running a heavy center diff.
Heading to the track tomorrow, may make some other setup changes to it as well to increase steering. Sadly the camber links aren't vertically adjustable so I can't change the roll center to modify transition response. Which is one of my favorite changes to make. :(
- 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
- Jammin X1 CRT Pro, MMM/1717, 6S
- Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
- Hyper 10TT, MMP/1410, 3S
- TL Mini 8ight, stock, 2S
