zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.20.2012, 12:15 PM
Did you take those IR readings through the charge leads, or the balance leads? You will get better results if you go by balance leads, that's how most results are retrieved, but that is cell performance, and not pack performance. Real world results should be read as pack performance as that is all that matters for performance... on the other hand, the lower the actual cell IR, the lower the pack temps will be. That is good, and to be expected from a pack that the IR goes down after some cycles when it hasn't been used in awhile.
My G3 packs went from ~15mohm down to whatever i said before... 5mohm? When new 3 years ago they were 3mohm.
