maxxdude1234
maxxdude1234's Avatar
04.02.2006, 11:13 AM
Originally Posted by GriffinRU
Well, I cannot say so because motor output (Motor Output = Total power * Efficiency) won't be the same across entire RPM range. And both motors will have similar (not the same though) current-torque curves with load or without (as long as it would be inside motor powerband, based on size). But with the same voltage one motor can be at pick efficiency while another not.
Artur
er.....please tell me what part of my post was incorrect? Your post, although correct, had nothing to do with mine. Please, if something I posted was incorrect then explain in what way it was incorrect - don't just say its wrong and don't explain why. Thanks
*edit* when I said "at a given speed both motors will put out the same power", I am refering to the speed of the vehicle they are moving. This might be where the confusion lies
