ANGRY-ALIEN
ANGRY-ALIEN's Avatar
06.13.2012, 11:02 AM
Hmmmm... it's been some time since i last made an update to this thread...
well the truck still runs, but it's not as frisky as it use to be... the upper deck plate was broken and there is not a lot of strength anymore, so that has forced me to squeeze a little less on the throttle...
I will be making some changes/improvements with the chassis design soon... I will be adding a new steering servo (Airtronics 94780m 423 Oz) to coup with the weight and torque this thing puts
out... I'll be changing the 23mm hex stuff to 17s... Hong Nor Shafts and the some Dace 17mm adapters will be installed... I'll also be modifying RPM knuckles to facilitate 16mm bearings...
I guess I'll be posting up the rebuild soon enough...
Alien
