chrismechanic
06.14.2012, 11:21 AM
Originally Posted by ANGRY-ALIEN View Post
That sounds like a plan Champ...
Zack... I think you are onto something here... I totally over looked that section... I was always building the shock to achieve 100% rebound...
according to this instruction, the shock requires much less... Tonight i will rebuild with the instructions below:
iv) Refi ll to the top.
v) Screw the cap on 1-2 turns.
vi) Fully compress the shock. You need to blead off the excess. If you tighten the cap
with this much oil in the shock it will hydrolock (fl uids are incompressible) and blow
the seals out. Do not do this with the spring perch installed, you want FULL travel
on the shock.
vii) Unscrew the cap a little until the pressure relieves and oil bleeds from under the
cap’s threads.
viii) Tighten the cap down. Wipe clean
Alien
this is why i am going to try the piggy back shocks....i tried it both ways...if you screw on the cap with the shaft down the socks will weep out oil ( i have even had the oil fill up the air gap between the cap and bladder, that bladder could have had a pin hole i suppose) or the shock will pop off the top cap on a heavy landing (plastic caps only) or blow the seals.
with the shaft fully up they suck air in after a while...due to the vacuum inside, or suck in the bladder on plastic shocks.
the best i found was to go half way..hard landing gave an amount of rebound and less vacum inside at ride height to suck in air...
seeing as they are alloy shocks i would try as the instructions said.....
so whats the reoccuring bladder problem? does it need to pee every half an hour?
cant wait to get my hands on the piggys...but i gotta wait a bit longer...its killing me
chris
