09.12.2012, 06:03 PM
Your top diagram looks almost OK - just move the black wire of the BEC to the battery pack negative (you have the BEC ground floating at 1/2 battery voltage - which is a big no-no).
Receiver's current capability is pretty much only limited by the size of the traces connecting the + and - pins, so around 3-4A before voltage drop starts becoming a concern. But since you are wiring the power to the servos separately, you don't have to worry about this.
