Another not so good update... or should i consider it a statement of the power we play with...
Thanks god no expensive electrics involved, went for some fun today, and managed to melt down, literary melt the Center Differential!
I measured 100 deg C !
Here are some pics : ......
100 deg C
the temp was measured couple of minutes after hearing the weird noises... thought the esc or motor then realized its the CD.
the oil is every where
The diff screws were dislocated, you can see the lower one as if bent, the screw is straight, but the melted plastic ....
This is melted plastic
Had to literary break it to get the internals out, getting them soaked and cleaned for further inspection.
