11.11.2012, 02:23 AM
Originally Posted by Brokenparts View Post
Can I use the traxxas CVDs? If not, what can I use?
I forgot to mention, I bent the crap out of my rear MIP CVDs. I think the setback arms may be a contributing factor. Maybe I should go with regular racer x arms and the UE mono block?
Yep, traxxas cvd's, you just need the 8mm cup for the diff end.
Lot's of people run setbacks with no problems. With those big tires you are running, that is going to happen. That's a ton of mass to rotate. I suggest smaller tires or stocking up on cvd's!
