11.20.2012, 10:46 PM
Yes, use the castle link to adjust the output of the bec.
Since you have a spectrum rx you could just wire it directly to the rx (NO bec) and pull the red wire from the esc. This would be the easiest way.
If you do as suicideneil diagramed you are correct, you leave the red wire from the esc intact.
