Originally Posted by Smokytyrz
If I let the truck sit for a moment, it will go again, but the behavior resumes very quickly. And it is always progressive.
If I unplug and restart then the whole process starts over again, beginning with full power output.
Thanks!
I would check the batteries, could be the ESC is cutting the power when voltage is too low! one damaged cell? check the led lights on your ESC, when the lipo cut off kicks in certain lights will go on in different color. at least on the CC ESC, namely the MMM if you have that one.
