agw
11.30.2012, 12:14 AM
You can spin those nuts and put the nylon part on first. If it's a flanged nut just use a washer for the flange. Also, loctite is your friend
Not a bad idea at all but it turns out that the flanged nuts I was using were just too big. I switched to the same M5 I had before and put a little washer instead. Now I have no problem...well not that problem anyway...
Must find a large parking lot with no cars...
