WheelMan
Do Epic Sh!t
WheelMan's Avatar
11.30.2012, 03:19 PM
I hope you didn't pay much. You are also missing the blue ring (basically a rubber ring). It was the combination of the missing plate and missing blue ring that made the slipper what it was. Those two parts spread out the pressure on the slipper, instead of having all the pressure centered on the little spring. More even pressure made the spur gear run more true.
I'm sorry to say, but I think you are SOL. Both because of the missing parts and the fact that they are just two different designs of slipper, I don't see the strobe working on a 3903 trans.
Also, the strobe was an upgrade to the 3906 (you know this). The 3903 has a "revo spec" slipper that is just as good, or better than a strobe.
It's kind of a pointless upgrade, I'd actually consider it a downgrade.
Sorry man
Hmm damn......well ...
I see now after some more research that the sprong and larger nut were sold seperately from the strobe setup. Wish I had done my research better before I bought this.
But its mine now, so I will have to make it work. I've spoken with the guy I bought the strobe from on ebay (user onelosenut), and he is going to try and get me a UE nut and sprong. If I can get those, along with a 3903 rear pressure plate and slipper plate/disc (assuming its the same diameter as the 3906 style), I should be able to make the strobe work.
I assume the 3903 slipper you're talking about is the one that looks like a strobe, but has 3 mounts to the spur instead of 4, and uses 3 little slipper pads on one side instead of the two disc style slippers on either side of the strobe? I probably should have just went with one of these and called it good huh? lol
oh well, lesson learned. Thank you for the info though, much appreciated
-Travis
Edit: I should have added that I am building this truck from scratch, so this slipper is not a replacement. So I didn't have anything to begin with. I purchased the Strobe not knowing the old and new tranny's used different style top shafts...ie, hex vs pin drive. My mistake, poor planning, lack of research...I saw the strobe, for a good price, and impulse bought. lol Either way, I will find a way to make it work
Challenge Accepted!!
Adults are just kids, with money.
Common sense, is not so common.
