Originally Posted by brainanator
Some of the issues sounds like a badly calibrated radio system. Make sure you recalibrate the throttle range on the ESC.
THIS!!!
Monster, make sure you go thru the throttle recalibration after you do the update, every time. You may have to slightly alter the deadband width if that setting is enabled with the hpi controller.
I have had issues like you mention and a throttle recalibration sorted them out. Just do the std setup holding full throttle then power the controller, wait for the beeps, go to full reverse, wait for beeps and then let go to neutral. Should help.
