01.13.2013, 03:28 PM
Originally Posted by Emaxx Derek View Post
I am not sure what flm chassis I'm using. I trimmed the chassis the other night and turned the front mount over and got the slipperential mounted.
I measured the axle cups from end to end and got 76.2mm front and 133.35mm rear. I'm not sure how much room you should leave to get them in? I assume a couple mm each side.
I emailed Mike, rc alloys ( out of business), Kershaw design. I would like to get from Mike because I know they will be correct but I haven't heard back from him yet.
Mike doesn't really do driveshafts anymore, and Kershaw isn't the most reputable.
Measure to the bottom of the pin slot in the cup to the bottom of the pin slot in the other cup. If you use this as your pin to pin length the dog bone would be tight, so subtract 2mm for each side, or 4mm for the overall length.
savage xl rear dogbone is 142mm. Cut a straw or dowel or coat hanger to 142 and see how it fits.
Are you running traxxas diffs front and rear?
