KMN
KMN's Avatar
03.02.2013, 09:09 PM
You can get a 2.5mm allen wrench in one side and see if tightening it up helps. There's a bolt that goes through the diff and holds the balls, spring, washers, and d-rings in place. If that gets too loose, the diff will slip.
