nativepaul
nativepaul's Avatar
09.11.2013, 01:35 PM
Originally Posted by nastety92 View Post
There will be a toggle switch inside the truck and that will get turned on so it will lock the rear caliper, then once I go to launch the truck it will release freeing the rear wheels. It's not setup yet, but hopefully it will be soon and I'll have more info.
How would that be useful? Sounds interesting but I don't understand.
When you first mentioned it I was thinking of a drifter, wanting a rear only brake to initiate slides, adding a second calliper could potentially be easier than converting the existing handbrake/Ebrake to hydraulic on some vehicles. But for the drag strip I'm baffled, is it FWD? It could be for burnouts, but I thought trucks were all 4WD or RWD and I don't see the benefit in just burning out the front tyres on a 4WD.
Unless you have a front only brake too and burn out the fronts and rears separately which would be safer than doing all 4 together.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
