04.23.2014, 12:22 PM
Correct, this can use RCm mod one thread on pinions or the Losi thread on pinions for the LST series. Do not bother with the Losi pinions unless you use the TiN coated gears. I would suggest using the RCM pinions over all others as they are hardened.
And the DM1 does use mod1 pitch gears so you will be good to go.
