09.18.2014, 02:33 PM
Keep in mind that more voltage equals less amp draw when both setups experience the same load.
So if you have 2 identical trucks setup to run the same the speed, the higher voltage truck will have less amp draw than the lower voltage setup.
Less amp draw generally equals cooler components. Especially the speed control, which will likely be the same for both setups.
