Dr_T
Dr_T's Avatar
10.27.2014, 05:41 PM
Hi Lizard!
I'm thinking of getting those PMT tires for my 8ight-T, to try and get a bit faster than those "baloon assisted" runs I did on the Reely tires. I really like the 120mm OD size, as 140+mm would only increase wheelying and 97mm is too small for my gearing options. Would you recommend them?
Ideally, I would want to try and mount them onto some standard (97mm dia?) truggy wheels to avoid the whole squares thing and to use softer foam inlays. Held a pair today in a LHS and they're really hard. You know if they're sold somehwere as tire only? Have you tried ungluing them for using softer foam inlays?
