Thread: Arct1ks project
02.08.2015, 05:17 PM
Next up was replacing the front wheel bearing - I contacted RCR and bought one directly from them but for reference if you that the 3 bolt it is part WBI-513020 which Summit stocks.
ttp://www.summitracing.com/parts/wbi-513020
In addition you will likely need to do like I did and replace the studs with ARP 1007713.
Step 1 - Remove the old hub
Step 2 - Replace the studs on the new hub - I made a small jig to push out the installed ones on the bench without putting any load on the bearing. The new ones were installed by using the pull through method with some throwaway nuts.
Step 3 - Put everything back together again
Steps 4 - The result - No change :(
Click on picture for video...
So is it a bad batch of bearings or is this normal? I've torqued the stub axle bolt to the required 118ft/lbs.
