Dr_T
Dr_T's Avatar
06.22.2015, 02:01 PM
Originally Posted by Lizard View Post
Great, can't wait to see how it goes. I really hope you get what you ordered, according to TPPowerEurope, the 6D is 1260kv.
But why no cooling fins version? You wanted to have something that is in stock?
No fins is because I cheaped out: 5660 equivalent with fins (5840L, apparently shorter rotor, but same weight and Power, so more copper?) is over 200 EUR currently. TP's changing their specs all the time, the one I ordered seems to be a previous version; maybe that's why it was cheaper. Too bad the table doesn't list Rm:
Bit of a gamble, but we'll see. It's no custom work, so if I get a different motor, I'll send it back.
Originally Posted by ruudxd View Post
Sorry if it is a stupid question, but if you have a bigger pinion then spur, aren't you going away from the 1:1 ratio again?
Not a stupid question at all Ruud! Having a bigger pinion than spur just makes the gearing taller than 1:1, so with the center drive-shaft spinning even faster than the motor shaft. There's nothing 'magic' about 1:1 gearing, it just happens to work well with the typical 40 mm, high kv, motor set-up used by speedrunners. If motor RPM goes down though, you need taller gearing to achieve the same wheel-speed. Kershaw actually has some over the counter pinions up to 60T for use on lower kv 1/5th scale motors: http://kershawdesigns.com/KyoshoGT-2-5882Mount.htm.
