Lizard
Lizard's Avatar
11.04.2015, 06:17 AM
Yeah, I guess TPPower Europe is more a distributor than really part of TPPower.
Bruno told you the motor came like that from the factory?
Not sure on the shaft yet, I'm not very keen on hours of grinding. With the 32t 8mm bore Kershaw pinion I have I can get no-load speeds from 185kph to 207kph, I hope the 185kph gearing is going to be okay for running through a whole pack then I don't need to grind it down.
