11.13.2015, 11:56 AM
Also, you are installing it onto a G1, which has slightly more room(braces are slightly different and the mount piece is slightly rearward vs the G2 braces) - you will have no clearance issue if you simply move the shaft rearward as ruudxd mentioned without grinding the fins.
