jcflyer
04.25.2016, 09:13 PM
Ok I tried everything and took measurements the front two holes are 1/2mm off. There is no getting around it, if you try to enlarge the big square hole then the two rear screws won't line up. Another plate is what's needed with the holes in the proper place!!
