Thread: Custom Micro F1
d3lap
03.29.2018, 12:49 PM
So Im trying this new approach, Design a million times, print once ahah, to avoid the 8 prototype chassis, 2 sets of rims multiple top braces ordeal that I had previously.
Decided to make my own a-arms for two reasons:
1. adjustable camber (stance nation obv)..
2. Ball diff is wider than stock diff by ~3 mm's so adjustable length arms will keep my track width the same, but allow for the bigger diff.
Still not 100% sure on the ball diff design. Its very common that the belt sits on left or right side of the diff housing, to allow for the center pulley to accommodate both belts ie, rear belt on left, front belt on right.
So I will most likely be changing that, I also think I'm going to need a tightening screw in my diff, Im skeptical about the pressure being enough.
Anyway here is what I have so far..
