MaxxFusion
MaxxFusion's Avatar
04.13.2006, 11:08 AM
Originally Posted by cart213
If you are running stock electronics, the only upgrade you really need is a rpm bumper.
If you will be doing lots of jumping, you'll need to get big bore aluminum shock caps.
Another good all-around upgrade is rpm bearing carriers and bearings for the axles. The stock bushings will wear out rather quickly.
The pede was my first truck. I agree. You will want the RPM front bumper and front/rear RPM carries. The other thing I broke on my truck the second time it was out was the steering servo. Mine came with the 2018 which is junk. I think since they have upgrade the steering servo to the 2055 but not 100% sure on that. That was my second upgrade.
These are cool little trucks.
  Send a message via MSN to MaxxFusion
