04.16.2006, 03:46 PM
There's definitely something wrong with your motor or the connections. My guess is that the motor screws are too far in and hitting the windings. Otherwise the motor is not spinning freely or the timing on the controller is set too high. (You should set it to about 5 degrees timing)
