Originally Posted by infinite_loop
Thanks combat! Are the "two pin socket connectors" male servo/receiver connectors? Or would I have to change them?
Judging by the pin spacing, I'd say the connector is a standard PCB connector, so yes, you'll have to change them. You can cut the existing connector off the fan, pick up a connector pigtail of a $1 or so, and solder the wires together.
