04.19.2006, 11:12 PM
A 30watt iron sould be fine,it'll get the job done anyway,same temp usually,just takes longer to heat back up after you make a joint than a more powerful iron.I find soldering so much easer since i got an antex soldering station and a fume extractor,worth every penny if you solder often.
