Thread: over heat !!!!!
squeeforever
squeeforever's Avatar
04.21.2006, 07:34 PM
oops...i edited as you were typing lol. anywho, did you see if it will restart it imediately? i had similar problems right after my revos airfilter come off and got dirt into the motor. it would run fine and then about 4 passes down the street later and it would shut off because it lost compression and the motor would warm up and then loose compression and die then it wouldnt restart till it cooled off.
