Thread: over heat !!!!!
furryninjas
04.22.2006, 04:34 AM
Originally Posted by squeeforever
oops...i edited as you were typing lol. anywho, did you see if it will restart it imediately? i had similar problems right after my revos airfilter come off and got dirt into the motor. it would run fine and then about 4 passes down the street later and it would shut off because it lost compression and the motor would warm up and then loose compression and die then it wouldnt restart till it cooled off.
that is EXACTLY what was happening......
well i tore the motor apart as far as i possibly could tonight, didn't know such a small carb had so many pieces, and cleaned everything with Q-tips and after-run oil. i couldn't fully take it apart because i dont have a clutch tool, couldn't even get the spring off, so i just hope i got it cleaned up good enough, guess ill find out tomarrow..... oh, also blew air through the carb to clean out clogged jet holes, yeah, some sand did come out......
