James
04.23.2006, 01:54 AM
I think i might just go with a sensoreless motor. Is this the esc that you can program for Acceleration, or top end or something like that. will i need anything else? And can i use the plane 4s lipos from towerhobbies.com? Are they really crapy because there cheap.
This is what i might get
MGM Compro 80 amp, 12 cell brushless car controller $185.00 $185.00
feigao5408s Feigao brushless motor 540 8s
Or could i go with this?
Nemesis
8,9 or 10L
36mm x 61mm 282 grams
6-12 cells* - 5mm motor shaft
Nemesis Blue Motor Specs Chart
Castle Barracuda 80 - 80 amps cont. 120 amps surge. 5-20 cells, waterproof, pistol grip compatible.
Hacker Master/Navy 70 - 70 amps cont. 7-16 cells, Waterproof, water-cooled and pistol grip compatible.
540 8L - Castle 80
540 9L - Castle 80
540 10L- Castle 80
540 8L - Hacker 70
540 9L - Hacker 70
540 10L- Hacker 70
All combos just 264.95 each!
Quantity
The only thing is the hacker esc is water cooled. And will a 8l be to much for a pede? It the Hacker esc programable?
Or this
Brushless High Power Electric Motors
Three motor sizes
540 S for 4-8 cells*
35.8mm dia x 51mm long
225 grams 1/8th shaft
540 L for 6-12 cells*
35.8mm dia x 60 long 282grams
5mm motor shaft.
540 XL 10 cells and up!*
35.8mm dia x 74mm long 372grams
5mm motor shaft.
Standard Features
50,000 rpm bearings!
Aluminum Purple Anodized Casing with 2-Pole Neo Magnets
& Compressed Windings
Feigao Motors
These are the same motors as the "Nemesis Blue" Motors being sold on other sites. Only ours are Purple.
Info on Feigao can be found here.
If your a sport boater or top notch racer on a budget, the Feigao motor is the Brushless motor for you! Feigao high performance brushless motors have the rpm and motor efficiency similar to that of Brushless motors that are Two times higher in Price! And for a limited time take advantage of our Combo Deals! We are packaging a high quality Castle Creations Control with a Motor for an even larger savings! At these prices you can get both the controller and motor for about the cost of a single competitors motor only!! Water cooling these is normally not necessary, but in extreme setups or racing Use Gundert 500 size motor jacket to cool the 540S series of motors and the 600 series water jackets to water cool the 540L and 540XL series motors.
Click here for Feigao Motor Chart
Example of Motor Description
Example motor: "540 7L 3,511 RPM per Volt"
540 is the Diameter of the Motor Housing
"7" stands for the number of turns
"L" Large - stands for the length of the Motor Housing
3,511 rpm per volt. RPM/volt x pack voltage = Total RPM
Only $69.99 for the "S" series Brushless motors. Good for approx 6-8 cells.*
1/8" shaft
35.8mm dia. x 51 long 225gr
540 7S 5,070 RPM per Volt*
540 8S 4,436 RPM per Volt*
540 12S 2,958 RPM per Volt*
Only $79.99 for the "L" series Brushless motors. Good for approx 6-12 cells.* 5mm shaft
35.8mm dia. x 60 long 282gr
540 7L 3,511 RPM per Volt*
540 8L 3,072 RPM per Volt*
540 9L 2,731 RPM per Volt*
540 10L 2,458 RPM per Volt*
Only $89.99 for the "XL" series Brushless motors. Good for about 10 cell and up.* 5mm shaft
35.8mm dia. x 74mm long 372gr
540 7XL 2,382 RPM per Volt*
540 8XL 2,084 RPM per Volt*
540 9XL 1,853 RPM per Volt*
540 10XL 1,668 RPM per Volt*
540 12XL 1,390 RPM per Volt*
540 13XL 1,283 RPM per Volt*
Brushless Motor and Control Combo Deals!
Castle Creations Barracuda 80 Marine Control
and Feigao Motor!
Click here for info on the Castle Creations Barracuda 80
Castle Creations 80 Barracuda Marine Control and Feigao Short (S)Brushless Motor!
Only $219.99
540 7S & Castle 80 Barracuda Control
540 8S & Castle 80 Barracuda Control
540 12S & Castle 80 Barracuda Control
Castle Creations 80 Barracuda Marine Control and Feigao Long (L)Brushless Motor!
Only $224.99
