nl12
nl12's Avatar
04.25.2006, 08:29 AM
Batteries are the most important part of you system, If you are willing to carry the weight of 36 cells I would suggest a 10sp2 lipo setup it will weigh the same or less and deliver the power that motor needs and give you very long runtime. A 400$ motor and a 400$ controler should go with 400$ batteries, not 50$ or 50 cent batteries. It would be like trying to run a car on cat pee. Now 400$ batteries are not nessisary but personally I would go with no less than some 3800s or 4200s quality cells. But seriously if you want to run a 2250 throw the budget out the window because to build an emaxx to handle that type of power will not be cheap, I would go with the best stuff ue has and cross my fingers... dragging around 36 cells will stress your drivetrain like crazy. I would like to see it done it would be a neat truck, I wouldnt mind drag racing you with my Jammin CRT 2240 8s lipo...:eek:
