04.26.2006, 08:18 PM
No, the rear will not work - too short for the cvds to fit, if you had a custom chassis made for it, you could widen the chassis at the back to move the arm mounts out further, which would let you run them. To be hoenst though the rears are strong and pretty unlikely to fail on you.
The RPM arms are pretty indestructable - I've never broken one, the key to it is they're pretty flexible when enough load is put on them, but they always return to their original shape. Same goes for any RPM parts - in my opinion its some of the best parts you can buy for bashing.
