04.27.2006, 11:55 AM
The higher the cellcount on the same motor (assuming you use the same pinion/spur) the higher the current.
If you use the 4000 and they are 20C, that setup can deliver 2960 watts, that's enough in my eyes, but ever since you have got an indomitable need for power, you might as well get the 8000mAh, and yes, the 36120 can take 11S lipo. If you are going for such a high power setup, please reconsider the choice of your controller and get an 36150 instead.
Now, please tell me... because i am burning of curiousity.. What is your plan with this setup?
