Gustav
Gustav's Avatar
04.27.2006, 02:30 PM
It is a little thing with the way the antenna wire is run inside the rx.
That fault was inside the transmitter,if it's the 'shut down' fault they show on their site.It's the way the antenna is routed inside the transmitter,if it's routed over the board it's too short and needs to be relaced,it should go under the board,anyone with a DX3 needs to open the transmitter to check.
Edit:er,it doesn't apply to the DX3(i think),that fault is definately within the transmitter module but it's just for people using modules.http://www.spektrumrc.com/Articles/HobbyWire.aspx
