Thunderbruiser
Thunderbruiser's Avatar
04.27.2006, 06:26 PM
Originally Posted by Jato Killer
Yeah, my 3S gives his 12 cell rig a good run for his money, but it falls just a little bit short. Some more gear, and I could easily pull him with my 9920 controller, -but it would get hot. Geared the way it is right now (20/87), the power meter shows max current at around 90 amps, -so I'm already knockin' on the door of being "done", -at least with a 3S. I have the advantage on overall weight, -his rig is heavy, -which does make it more stable at the higher speeds.
this is true......i wonder if you bumped up to 4s and ran a fan on everything would you smoke him? I just bought two 8000 mah 2's and 1 3s and a hyperion charger....for my bl project...it should prove to be pretty darn fast
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
