Jato Killer
RC JUNKIE
Jato Killer's Avatar
04.27.2006, 06:35 PM
Originally Posted by Thunderbruiser
this is true......i wonder if you bumped up to 4s and ran a fan on everything would you smoke him? I just bought two 8000 mah 2's and 1 3s and a hyperion charger....for my bl project...it should prove to be pretty darn fast
Oh yeah, I could spank him easily with a 4S, -and it probably wouldn't overheat if I geared down (which I would need to do anyway). I know that my 7020 can tolerate short 90 amp bursts without going thermal, -so I would like to think that the 9920 would be good for a short run at 120-130 without shutting down.
So, how are you going to arrange your (2) 2S (1) 3S setup? -Or did you plan on even doing that?
I'm always curious about people's success/failure stories about mixing and matching lipoly packs in series and parallel setups.
Regardless, your setup will be plenty fast.
BL RULES!!
GO BRUSHLESS, -OR GO HOME!
