sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
04.28.2006, 02:37 PM
the type of cells are fine.....just watch the # of cells.....keep in mind your running 24 Volts thru the controller........also can the motor handle the rpm.......I think the max RPM it can handle is 80,000 rpm....and with a rpm rating of 1502 per volt.....* 24 V you will be running at a rpm of 36,000 give or take a few.....which is fine for the motor.....just sharing some info with you......LMK how it goes....
  Send a message via MSN to sjcrss
