Thread: BL Rockcrawler?
GriffinRU
05.04.2006, 07:31 PM
What kind of run times you get and how was the torque?
I may try one to see. I don't know which one will bolt up.
I have a mgm 12012. I think that would work out for a test run.
I was getting around 12-15 minutes, but it was very light truck. It had t-maxx chassis and e-maxx tranny with 1/8 buggy wheels. Motor was too big in diameter to fit on stock e-maxx mount, so custom motor mount was fabricated and tranny become single speed with AXI motor driving idler gear direct. With ability to switch motor location from front to back. Later it was simplified with tiny wheels and Dewalt motor.
I used 13t gear from e-maxx tranny input shaft, after drilling it out to 6mm, as pinion for 6mm AXI motor shaft. Now you can get mod1 gear with 6mm bore from Mike.
You will have some challenges with motor cooling and rotating parts :)
Artur
