Dafni
Dafni's Avatar
05.18.2006, 04:59 PM
nl12, your adapter plate wont fit a torsen diff. But actually it would be very easy to make an adapter for an (ofna) torsen, because the piece which holds the bearing and the output shaft is not part of the spur. You would only need to make a disc with a big hole in the center and 6 small holes around (the ofna torsen uses only 2 screws to attach the spur to the diff)
