5mm bore, mod1 pitch pinion
capitol
5mm bore, mod1 pitch pinion - 05.19.2006, 05:17 PM
As I understand it Mike is the only fella that sells 5mm bore, mod1 pitch pinion gears. I've been waiting weeks for him to get them in stock and unfortunately its holding up completion of my emaxx. I happen to have an extra UE idler gear if anyone wants to trade for a 20 or 18 tooth pinion gear.
These are the items Im going to purchase. No point in buying though if the pinion is out of stock.
BK Electronics Wanderer "9XL" Brushless Motor
Warrior 9920 Brushless Car Controller
5mm bore, mod1 pitch pinion 18/20 tooth
RC-Monster Brushless Heatsink/clamp
Strobe Slipper Kit w/Bearings
External BEC/UBEC
Nylon 51 tooth spur gear - Ofna
5.5 mm connectors
I was wondering if there is a different BL motor that uses a common pinion gear found at a LHS? Maybe I should just go with a different motor :032:
