05.22.2006, 06:43 PM
I'll bet that this LiSaver issue has to do with its use in airplanes. With a stick radio in an airplane, the throttle all the way down means that the motor gets no power. In a car, this translates to full reverse. If you have reverse disabled on your controller, then it will just slam on the brakes instead, which wouldn't be nearly as bad.
