Thread: testing my 2240
nl12
nl12's Avatar
05.30.2006, 09:32 AM
so I did a bad thing, :002: the spark was like the kind you get when you connect hi voltage packs to the controler, I suspect it was from flux on the connector which made a high resistance connection that under high load sparked to an area of lower resistance on the plug. I was just wondering if anyone else had something like this happen to them or knew why it may have happened.
