captain harlock
RC-Monster Captain
captain harlock's Avatar
04.05.2005, 05:26 AM
Well, I really didn't connect the motor to the spur gear yet, but you know, the motor for some reason stopped that wierd sound and its working fine now( after reprogramming the damn ESC) and about the 80,000 rpms, how did you know that the motor will be making such a high rpm rate? when I calculated the whole thing myself the motor was supposed to run at 55000 or more rpms, since the 1930/5 turn is rated at 4180 RPMs per volt so this rpm rate multiplied by 12-13.2 volts will give the 55000 rpms I guess and the receiver pack...Lehner said that I should be using 4 cells if the transmitter, servo and receiver are made by FUTABA.
Nice to meet you!
