06.06.2006, 09:53 AM
Originally Posted by Serum
They are beefy, untill you crash them once. then you need to reposition the pins on the male plugs. you need to feel a rather firm resistance when plugging/unplugging them.
I've crashed mine numerous times and those 5.5mm plugs are still tight. As a matter of fact, I tried to pull them apart once and ended up yanking the heatshrink off instead. If they ever get a little loose, I'd just use a tiny screwdriver to gently and slightly spread the prongs on the male plug.
